Guys am using HTC desire hd,am new in this machine.I tried to find how can i access my memory card but I couldnt find where is it.
Can any one tell me how to achieve that?
With your SD card inserted in your phone, plug your phone into your PC with the USB cable. In the notification area you should see a USB icon. Pull down the notification bar and tap on USB connected. You should now be asked to enable USB storage. Once you enable that, your SD card will be displayed on your PC as a removable flash drive. You can copy files to and from it directly.
