Hi, There appears to be a number of threads around this forum about storage issues, however none disaplying the issue I seek clarification on.
I have a new HTC Explorer A310b (sourced exclusively by vodafone in australia..this point becomes an issue a little later), rather than the A310e. Both models being unlocked versions.
These models were released only in June 2012 (I believe)
I have very little on the sd memory card, however the internal storage is almost full. To this end it will not install anything further, as (as confirmed by htc) everytrhing is stored on the internal memory at least initially, and then 'may' be moved.
HTC have advised that I should see an option 'move to sd/memory card' in the manage apps area for ones that can be moved to the card.
This has not and does not appear once.
I clearly need to find a way to install anything new or changed to the sd card, does anyone know a way to facilitate this.
The vodafone apps are not large, they are all on the internal stroage and make up the system files....so in the main cannot be moved.
My other phone is a also an unlocked htc, but this one is a desire hd, which I have not had the same issue with (needing to move stuff to the card, or having a near full internal memory).
A bit perplexed over this especially being such a new model handset.
Any advise or direction (or clarification request), would be welcome.
regards
Lethal1
regards
Lethal1
