Help Storage Problems
OK so I am getting puffed out now lol !!!
I was under the the impression that rooting my new galaxy tab 2 7.0, I would be able to use my 32GB SD card as the default storage. However i have now rooted my device and installed link2sd but now its talking about partitions and stuff.
please any help or give a decent straight forward walk through, I would be grateful.
Thank You...
read more about link2sd,
it uses a second partition on the sdcard to move all you apps and uses that partition like internal memory.
I have tried this on my SG Ace but not on the tab so be sure what you are doing and also make sure the type of partition you do is supported by the rom that you are using.
