Hello everybody.
I need to know how to disable the multi user interface in my note 10.1 rooted with pacman rom in jelly bean 4.3.
It is always duplicating the files that I put in it.
For example, if I put the NFS most wanted data files in the android/data folder it gets repeated three or four times in other folders.
If I put it in the emulated/0 folder it gets duplicated and it is present in storage and media and some other folder.
Hence the approx 1 GB file becomes 3-4 GB.
I'm guessing this is due to the multi user interface.
Also I have another problem
The USB connection isn't working.
If I plug it into the pc it doesn't show upon my computer but it charges.
If I out it in USB debugging mode the PC makes the connected sound but I still can't access the folders.
I need help.
I need help.
