Straight to SD (not asking how do do it)
jaybo1973
Android Expert
Hi all
Over the last couple of days I have noticed that some apps have started going straight to SD? I have not followed the procedure favoured on here for forcing apps to SD (yet) So why are they doing it? Its not a problem as I was going to move them anyway.
Cheers
some new apps might have been mede to install straight onto sd card with froyo. thats all i can think off:confused:
if so its a good addition
App devs can choose whether to move apps to the sd card automatically, make it an option if the user decides to move it, or not allow it to be moved(which is the default).
pm setInstallLocation 1 in adb shell, that'll force installs to internal, 0 is automatic (app decides on its own depending on dev) and 2 is SDcard. Type pm getInstallLocation to see what it's set at.
Sorry mate. I dont really understand this message. If whatever setting is on,it must have always been on as I have changed nothing. Just started doing it??
Maybe its because I have less than 10% internal memory left?
