RobbytheRobot
Just got a Sony Xperia M2 and still exploring optimum battery life. Generally getting 2 days out of it while playing with phone quite a bit so am pleased with that!
Had gsam battery monitor on my old Sony Xperia E and seemed pretty accurate.
However, on the new phone my screen usage is being reported as 2% and app usage at 98% - this is with over 5 hours screen on usage with the battery depleted to 30% which surely can't be right?
The stock app reports 8% screen usage which can't be accurate either unless Sony have come up with some new tech whereby screen use uses the least juice of anything?
I'm on Android 4.4.4 if that makes any difference or helps!
