3ricG
When I press the home button to view all my homescreens at once, only one displays. What could be causing this? Here is a video of the problem
thats a new one....never seen it before
obviously try a reboot
after that, not sure what to tell you. if you can find the HTC launcher in the app list i would try to clear cache on that.
then a factory reset would be my next guess to fix it.
on a side note, what is that home screen recorded app....looks cool, works great
same issue here! where do i find htc sense and reboot?
nope! it didnt.... i use go launcher as my custom screen and when i hit the home screen it changes so i have to hit the go app icon to set it back... thanks for ur helpSettings>applications>manage applications>all>HTC sense>force close
After you force close the app, return to the home screen. Sense will reload, and the problem should be fixed.
Let me know if that doesn't fix it!
