Help strange icon
D
Deleted User
Guest
Hi does anyone know what this icon is on the top left?
Looks like you have the mobile hot spot turned on, and a couple of devices using it.
*edit* Ninja'd!
On second thought, shouldn't the wifi icon be off though?
thank you for the replies, I've checked it but its not connected or on :confused:
Yep, you're right, turning it on disables wifi. Here it is on mine, with one connection. It's over to the right with the system icons, instead of to the left where the app icons would be.
Edit: Jammy, you should be able to pull the notification panel down, long press on the corresponding message, and select App info.
hi I tried it but just takes me to the system UI screen.
Sorry busy watching football, heres the mobile hotspot icon. My phone is rooted with omega rom, not sure its someone to do with the mods.
