spyder
Hello.
Well I'm running CM7, NO COMPLAINTS. It's running with no glitches, BUT I noticed with the last couple releases, the MMS works just fine, BUT:
The sending party, HAS to add a "Subject Line" or I WILL NOT receive it. If they attach a pic, put a subject line, comes right thru. No subject line, it's like it never existed.
For me sending same, IF I send a pic OR a msg >160 Characters, if I do NOT put a subject line, it bounces back "COULD NOT BE SENT NOT A VALID #"
THEN, I add a subject line and boom, no problem at all, goes right thru?
When I hit add subject, it even comes up and says, converting to MMS.
The stock ROM did that when you exceeded 160, not sure about the pix.
It's not a prob. BUT if the person sending me a pic does not know to do it, I won't receive and they will NOT get a bounce back so they will think I got it, that's the only problem.
Oh well...any thoughts...Jeff
