I've been having a strange problem, and not only don't I know how to solve it, I can't find any write-up even on what might be going on. This is on a Google Samsung Galaxy Nexus, still on the original ICS.
At the top right of my phone, just to the left of the battery charge indicator, there are the vertical blue bars that indicate the strength of the network connection, and to the left of them are the "fan shaped" bars that indicate the strength of the Wi-Fi connection.
When everything is working well, these indicators are all a light blue color, same as the battery indicator and time. Every so often though, for no apparent reason, the color changes to white, at which time the Wi-Fi may not work properly even though the (white) bars indicate I'm still connected. Invariably, when this happens, turning Wi-Fi off and turning it back on again seems to fix everything.
First question - what do the different colors, 'blue' or 'white' mean on these indicators?
Second question - if in fact, they need to remain blue, for everything to work properly, how do I fix this?
(As a test, I switched 'airplane mode' on, and then off. These indicators both came on, one at a time, switching back and forth between white and blue coloring, and finally settled with blue. Not sure this means anything or not.)
