Root Strange occurance
idbl_fanatic
I am running CM7 Beta 8, the last couple of weeks, when I wake up every morning, I have to reboot the phone, because it says "No service" and has the "X" by the antenna icon.
Has anyone else seen this?
Did you put this update over another without fully wiping?
If so do a nandroid and then full wipe. Then reinstall.
If not, Have you checked your settings? Use the voice dialer and say "Open Apns", it may take several tries but once you get it open make sure it is lit up. That might help.
Ok, I will give that a try, I downloaded APN manager, and it was not "on" so I turned it on now, we will see how it goes.
Thanks for the tip
yes this happens to me randomly. when it does happen, it'll pretty much happen every morning for days. i toggle airplane mode a few times. happens on stock too.
hasn't happened in a few weeks for me.
this phone does a lot of weird things. this current triumph, when I first got it, wouldn't play music in loud mode at all for the first few weeks. that's why i thought it didn't have the notification glitch. but now it's back to "normal" for what the triumph is "supposed" to do
weirdest yet, i got this strange ringer while the phone was in my pocket. haven't checked to see if it's a stock ringtone. hit the power button, screen turned on, it stopped ringing. no idea where it came from. I'm sure it's some app I have, but I've never heard it before, and have no notification of it. And it rang for a good 20 seconds too, since I was waiting to see if the screen would light.
Well it stayed on over night, and I have noticed that my speeds are much faster now, we'll see how it goes, thanks again.
