Help Strange problem
Have a D1 running stock. Was working fine, then the strange happened. The left side of the phone stopped working. None of the icons on the screen or the back arrow. Everything else seems to be working. If I set it to the phone log the phone will begin to make calls on its own. So do I go for a new one or is there a fix for this?
sounds like your screen went out so I would take it to verizon....should be covered under the manufacture warranty depending on when you bought the phone
