Root Strange rooting problem
bigbdroid
Hi all,
I just rooted my phone using this as my guideHow to Root/ROM Your HTC Evo V 4g with HTCdev and Fastboot - Android Forums at AndroidCentral.com
However, the strange thing is that I can't use any terminal emulator to do root commands. I can't even do the super simple command "reboot". My question is why can't I do any push commands?
I have used su checker and everything checks out except for sudo. I have even flashed miui and harmonia to no avail. They work but I still can't use push commands.
I'm currently running:
stock "patched" rom
twrp 2.3.3.0 recovery (I've used 1.1.1 and all the others)
busybox 1.20.2
stock hboot (unlocked) s-on
if I forgot anything that you might need to know please ask.
Hi all,
Use "su" to get a root command prompt. The "sudo" command is not available in Android.
ramjet73
I know all this and I do use su to get to root.
My question is why does the su command not give me full permission?
I have cleared superuser of all apps and had them re-request su privlages. I choose allow. I enter su. The every command returns not permitted.
Oh and I just started getting an error message in recovery.
E: bad boot message
"time"
E: bad boot message
"time"
Did you change your bootloader or recovery? If so, format dalvik+cache and reboot recovery.
All the commands supported by busybox work fine for me in the terminal emulator app once I issue the "su" command and approve the superuser access request.
You do have busybox installed, right?
ramjet73
ramjet73
I haven't done anything to the bootloader other than the unlock through hdev. I started originally with twrp 1.1.1 and moved up to their touch recovery. Did the wipe. And busybox installed without issue.
