Strange Screen behaviour when on BT calls
jmdearras
Hiw do you control the screen being on or off during a call? My screen blanks, I guess to keep you from hitting buttons with your ear, but when using a bluetooth headset it also blanks. Sometimes tilting the phone wakes the display, sometime the top button does. But sometimes neither hs an effect, and the screen remains off until the call is over.
Anyone else have this, and figure it out? Are there settings somewhere to control this behaviour?
Thanks,
Jim
When the screen blanks sitting in the palm of your hand means that the phone is just locking its self. Either change the screen timeout or just unlock it.
I've been having all sorts of goofy BT problems but I was just chalking some of it up to my BT device.
1. I notice the phone kinda becomes unresponsive at times with the Bluetooth on, which would exhibit the behavior your having.
2. sometimes I have to turn Bluetooth off and on- on the phone for it to fully recognize that my Bluetooth device is a headphone and media device.
hopefully that gets looked at.
The phone has a proximity sensor for when you take calls... if you look carefully you can see it next to the verizon logo on the opposite side of the LED. Whether you are on a call with BT or not... the phone uses that proximity sensor the same way as if you are holding it close to your face.
The result is, if your hand comes near that sensor, the screen will go blank cause the phone thinks you are holding it close to your head. I've tried various apps to adjust this before knowing what the cause, but since discovering out exactly what is taking place and how it's working, It no longer seems to be such an issue... just something to make note of when handling my phone while making a call with bluetooth.
so yeahh.. I know of no app that will shut off the proximity sensor during calls involving a bluetooth headset.
