Hello,
Well i searched and found nothing, hence new post. Hope you will not flame me.
So. Z1 makes a strange high pitched short sound which comes from upper part of phone i think, when:
Typing on calling keypad (happens only when settings->device->sound on touch is enabled)
Get a notification (needs vibrate on touch enabled. MOSTLY. Sometimes even happens with that option disabled)
click home/back/task button (needs vibrate on touch. When i disable that strange sound in this case stops showing)
Worth mentioning: It happened on stock 4.2.2 and is still happening on 4.4.2. Update didnt helped.
Factory wipe didnt helped.
I do still have default notofication sound chosen. So the sound i write here is not related to choosing diff. in settings.
Lowering all possible volume levels to zero strangely also doesnt makes that strange sound go away. It still happens despite of the fact that phone should be absolute silent.
And last but not least when that sound happens, MOST of the times a vibration that should be in place of that sound is not present. Just doesnt happen. Rarely it happens that there is that strange sound and a vibration but its really rare. So most of the times it looks like vibration that should happen transforms itself into that strange sound.
I have read on some forum that this may be a known issue for some z1 phones, rather hardware one, related to buzzer itself. Is that true ?? Can i repair it under warranty ?? Anyone heard about that ?? Any info appreciated
