matthew9170
Sorry if this is in the wrong section, but i have a problem when I try to root my strato. I try to install a different kernel like knightcrusader's and I am almost certain it didnt work. I have CWM-recovery installed correctly I think via the odin method and now after I installed CWM odin no longer sees my strato. I try to install the SU binary and cwm says it installed but the superuser app says that su is not installed. I installed the superuser app via cwm so i know that that part works.
Any help would be appreciated, thanks
-Matt
-Matt
