stuck at emergency mode
my optimus one was having android 2.2.1 and when i checked update through official LG suite IV it says software update available.i pressed update and after which it downloaded some update files and when it starts updating the phone,the phone rebooted and stuck at emergency mode screen whereas update software on pc shows me error after 5% that problem in connection with phone...now i tried "Home+vol down+power"..but it still shows emergency mode even after replacing battery.i tried KDZ updater but it also says phone not connected.
i already installed usbdrivers and tried again :(
plz help me my phone is in problem :'(
see for this issue in this same sub forum. there are some threads with problems and solutions.
And by the way, if you may have to disable all the other ports used by Optimus One, like the bluetooth, modem etc.. and then it shd work perfectly.
Welcome to AF ddeathgame. I hope you find a solution to your problem.
