Root Stuck at HBOOT Help
@notebook
Yeah. so whenever I turn my phone on, it launches straight into fastboot and all I can do is go betweem fastboot and bootloader. Nothing else. The first 4 lines are:
SAGA PVT SHIP S-ON RL
HBOOT-0.98.0000
RADIO-38.03.02.15_M
eMMC-boot
I'll give that a go and let you know.
Thanks
@robinson
Apologies, I should have said 'Try installing the RUU_Saga_S_HTC_Europe_2.10.401.9 RUU with the Gold card' instead of 'without the Gold card'.
Installing an stock RUU on a branded phone won't work as the phone will need an RUU from the same brand to install. If you tried this already, then all you'll get is an install error.
If the recovery option is not in the boot menu, then that doesn't look good - it's often indicative of a hardware problem, specifically an eMMC chip failure, which I'm beginning to think your problem is.
However, there is good news if your phone is still under warranty - as your phone is S-On and because of your Getvar info, repairs won't detect you've ever been rooted/S-Off.
@notebook
Will try doing that now. The recovery option is there but every time I run it, it boots straight back into bootloader.
Thanks for that little bit of advice you pm'd me though!
@notebook
I tried to install it with the goldcard in but I only got error 131.
Should I maybe try remaking the goldcard, make sure nothing went wrong with it?
@robinsona
There are a couple more things I can think of for you to do, before you consider returning it for repair (if that's a realistic option).
The first thing to try is to extract the ROM zip from the RUU.
Start the 1.31.351.1 RUU and once it's started up go to 'Start' on your Windows PC and enter 'Run' in the 'Start Search' dialog box. Then click open the 'Run' program and in the 'Run' dialogue box type %temp%. In the folder that opens up, you'll see a number of sub-folders. Look for the most recent one (which will have been created by running the RUU, and within that will be a ROM ZIP file*. Copy that to an SD card (not your Gold card) and rename it PB99IMG.
Then turn your phone on in HBOOT. Your phone should automatically find the PB99IMG file on your SD card and hopfully install the update from that.
*As you've run the 1.31.351.1 RUU before, it may already exist in the 'temp' directory.
Give this a go and let us know how you get on.
@notebook
I have already tried that process but I just got an error saying that it was older than "main version".
Any final suggestions this week would be really appreciated, otherwise I'm going to go into the virgin shop on Saturday and see if I can get it sent off.
Any suggestions as to what I should say, so that they don't suspect that I have rooted it before?
@robinsona
The only other thing I can think of is to try and get S-Off again via Revolutionary and flash the clockwork recovery mod.
The risk here is that if you acheive S-Off and change your HBoot, but can't get any further, then your phone's warranty will technically be invalid.
If you can't get Revolutionary to work, then I'm pretty sure your problem is related to the eMMC chip being fried. The most likely cause of this is due to the removal of the battery when the phone was on.
If you send your phone in for repair, remember to remove the SIM and especially the SD card! All you need to say is that it won't get beyond the Hboot screen. The techs will run some diagnostics on it and find they need to re-flash the ROM and/or replace the motherboard.
@notebook
I tried that too earlier as far as I can remember. I think I'll just return it on Saturday and hope for the best.
Thanks SO much for all your help!
Really appreciate it.
Alex
Hi again,
I've now created goldcard successfully. I've followed all the steps in the link and after i pasted the hex value from 000 to 170 the sd card worked . earlier format card alert msg used to prompt all the time. I've created gold card in my 2 microsd card. but i cannot install any rom./ruu either by running exe or PB88IMG.zip file. ends with wrong customer id or incorrect bootloader version message. if i put PB99IMG.zip then nothing will happen. it just ignore that file.
any tricks ??
Thanks FoX777 for the quick reply.
I not sure the goldcard I created was correct because It crashed when I coped that file to my memory and I had to format my sdcard. When I created that goldcard my phone was working fine so I didn't bothered to make goldcard again. luckily [unfotunately coz the file was not right] that file was stored somewhere in download folder and I tried with that. I don't have microsd card adapter as I have only SD card reader in my laptop, I couldn't make another goldcard. I've ordered adapter from amazon for that and I'll try that after few days when I get it. I think where i've made mistake. because I didn't remember reversing the sdcard ID to create CID, which is number 6 in this link [GUIDE][30/06/2011]Root AND Downgrade Desire Z/G2(S-OFF/ClockWorkMod) -No Gingerbread - xda-developers. And yes I tried to install 2.10.401.8 EUROPE RUU but couldn't install must be beacuse of Goldcard.
I'll update the thread with the solution if I could solve this one.
Thanks for the help.
Sorry about that,Typing mistake :) , I renamed rom.zip to PG88IMG.zip .
---I am still sticking with the goldcard wasn't created correctly.
Goldcard should be correct, I believe, because when I copied goldcardimage data to the sector 0 of my card and saved it. The card opens fine and When I checked sector 0 of the card, the value is same as GoldCard I've created. Is there any other way to check that?
the HBoot starts installation using PG88IMG.zip but received an error
'Main Version is Older!'
when tried to install rom.zip from RUU_Saga_H3G_UK_1.31.771.1_Radio_20.28b.30.0805U_38.03.02.14_M_release_178937_signed.exe,
and
error message
'CID incorrect!'
update fail!
Press <power> to reboot
when I tried to install rom.zip from
RUU_Saga_S_HTC_Europe_2.10.401.8_Radio_20.4801.30.0822U_3822.10.08.04_M_release_225161_signed.exe
While installing, the installation indicator(like loading..) is blue in the beginning and it completes normally and another indicator starts which is of yellow color, and stops at about 99%.. ( text 'Checking..[PG88IMG.zip]' is displayed during this time)
BB-00-03-E1-F9-26-10-47-38-30-41-53-4D-54-02-00 is my CID
which become
BB0003E1F9261047383041534D540200
and then, reverse is
0002544D53413038471026F9E10300BB
Some tutorial said replace first two characters with 00. but in my case it's already 00. so I left it as it is now.
I used 0002544D53413038471026F9E10300BB as input in http://psas.revskills.de/?q=goldcard and selected android. downloaded the goldcard. Copied the hex value to sector 0 , 000 to 170 offset of my sdcard. I selected Open Disk> physical disk and then Removable drive. in HxD hex editor as administrator. I saved it. removed the SD card from drive, put it back , the drive was working fine. I copied the rom.zip file, renamed it to PG88IMG.zip .
but I could not complete the installation.
@uktel3315
Remane the rom.zip file to PG88IMG.zip.
@uktel3315
wrong
which become
CID-BB0003E1F9261047383041534D540200
Reversed-002045d4351403837401629f1e3000BB
Use RUU 2.10.401.8
@FoX777, First of all, Many thanks for your help.
I've tried the reversed cid that you posted as well but still It is not working. same error message, CID incorrect!
I tried the same with another microSD card also.
Here's how I get CID using ReadCID in Windows7 and SD card Adapter for MicroSD.
http://s14.postimage.org/ptak91bhd/sdcard_New_Micro_SD_1.png
Is this displaying correct CID value?
I selected Physical Disks while selecting SDCard in HxD hex editor.
while selecting physical disk, if I paste any goldcard into the drive and save it, the card will work fine without any problem in laptop after reinserting the card. but when I select Logical disk the card will not work after I save and display format disk window.
I'm using 8 gb microsd card. Could that be the reason?
Do I need 2 gb or smaller memory card ?
EDIT: I tested with 1gb Card, It didn't work.
its actual CID is 93-00-83-6E-E5-B1-10-30-30-30-30-30-4D-53-1B-00
@uktel3315
wrong
Use RUU 2.10.401.8
I've now fixed my Semi Bricked -HTC desire s by creating goldcard.
I've used some other htc phone to create a goldcard. But now I learned how to make my own goldcard without htc phones. But you'll need a SD Card adapter and SDCard reader in your laptop. Not the USB card reader, but The SD card reader which is orginally attached to your laptop.
There's 3 way of getting correct CID for your micro sd card.
I'll explain how to get CID in detail using all three Methods.
Method 1: (require working state HTC phone)
Method 2: (require HTC phone which support adb connection at the moment)
Method 3: (When your phone is semi bricked and you are stuck in Bootloader screen, You need MicroSD card adapter to fit in SD card reader of your laptop)
Method 1:
1) download Goldcard Helper from Google play (few days back it was android market)
2) open the application, you'll get Reversed CID directly.
3) don't do anything to this cid, it's a reverse cid final one that you can use directly.
Method 2: using adb
1) either use this application to get cid [PC Application] GoldCardTool - Android @ MoDaCo
or
go to console (cmd) , go to ... Android\android-sdk\platform-tools> where you have installed your android sdk. type
Code:
adb shell cat /sys/class/mmc_host/mmc2/mmc2:*/cid
Now you should get your cid.
You have to reverse the CID on your own. here's how you do that.
this is my CID
Code:
02544d53413038471026f9e10300bb0e
next step:
Code:
0e bb 00 03 e1 f9 26 10 47 38 30 41 53 4d 54 02
(reverse in 2 character pair)
next step:
Code:
00 bb 00 03 e1 f9 26 10 47 38 30 41 53 4d 54 02
(replace first 2 digit with 00)
next step: remove space
Code:
00bb0003e1f9261047383041534d5402
, this is your reversed CID.
METHOD 3: which I used, using PC SD card,
a) you need READCID from jo0ls' .Net stuff: Read secure digital (SD) card serial number from the CID
b) put ur microsd card in sdcard reader using MICROSD adapter. and run Runcid as administrator.
c) you should see something like this http://s14.postimage.org/ptak91bhd/sdcard_New_Micro_SD_1.png
d) now copy that RAW CID Byte.
it's
Code:
bb 00 03 e1 f9 26 10 47 38 30 41 53 4d 54 02 00
for my SD CARD,
e) simple reverse it in one step, remove last two character, and place 00 in the front, so your reverse cid is
Code:
You should get your CID by now using , I used method 3 while I fixed mine, but i've tested all three method and It gives the same result.
Now Use this CID to get Gold card.
1) get CID from above method.
or Guess ur CID until u get one ;) (Just kidding..)
2) Now use the reversed cid and Download Goldcard from this site (RevSkills | We deliver mobile forensic and analysis software solutions worldwide, Actually the direct link was Free HTC goldcard generator | RevSkills but It's not working today. May be the link is moved]
3) now Enable USB Debuging mode, select Disk mode and run goldcard tool from [PC Application] GoldCardTool - Android @ MoDaCo , or find latest version from some other site.
4) select gold card /correct drive and patch MMC.
5) download the RUU you want to install. (Tips: Choose one from your region)
6) open the ruu and go to %temp% , you can go there either from run (Win+r) or paste it in your windows explorer address bar. find a folder like {0a9sdf..00s} where you'll find rom.zip file.. which is your rom. now copy that file to the goldcard(ur mmc card) and rename it to PG88IMG.zip.
7) restart your phone to fastboot bootloader and select first option(I don't remember the name of the option,You'll find it anyway ;) )
8) It should install your ruu without any problem.
If you have any problem, after getting reverse CID using one of the above method, follow after step 5 Click here post by kashoulis, He's using HxD Hex editor, which is straight forward, But pay attention while selecting opendisk, You must select your card drive listed inPhysical Disks not in logical disk. if you choose logical disk, you have to format your disk..
once again Thanks FoX777 and kashoulis for your help.
