I have an old Droid X that I'm giving to one of my kids. It was having some issues and stopped booting in general.
I decided to sbf and opened up rsdlite, pointed to the sbf file I was told to use (since I took that nasty OTA update that made my phone not allow any sbf before it), and it failed.. hrm..
I moved the file to the C drive, ran rsdlite as admin (I'm on Windows 7) and tried again. ...Failed.
I then moved the sbf file to the directory of rsdlite and ran a long dos command to run the file in a specific way. (Basically the same exact thing, just through the command prompt).
Still, no good.
I decided to use the linux distro (1KDStaz_MX_4.5.604) to sbf and get everything back into working order. This is the one that worked for me in the past and I had faith it would work this time.
Burned a cd from the image, attempt 1, fail.
Created a bootable flash drive from the image, attempt 2, fail.
So now, I'm staring at an old Droid X with the red Moto logo. I can't get into recovery. I tried holding down Home and power but I never get anything beyond the M logo.
The Bootloader says..
Bootloader
30.04
Battery OK
OK to Program
Connect USB
Data Cable
Any help with this?
Still, no good.
Bootloader
30.04
Battery OK
OK to Program
Connect USB
Data Cable
Any help with this?
