Hi,
I have been running a version (probably old) of insertcoin on my desire for a few months now. But yesterday decided that I should upgrade my 4gb memory card to a 16gb one but completely forgot about the custom rom etc.
I don't have that memory card any more and the phone would not boot without it. So i thought it would be a good idea to go into recovery and wipe lots of things trying to get back to some sort of 'default' or 'factory setting'.
I then was able to get to recovery and try to flash the rom again but the rom wouldnt boot so after a load of fiddling im stuck.
The phone will not enter recovery when the sd card is inside and gets stuck on the white htc screen when i select recovery.
When the sd card isn't inside I can get to recovery, but there is no way for me to get the sd card back in to try and flash a new rom.
Any help would be appreciated
Thanks!
Thanks!
