Stuck blue pixel
sh3vlin
Hi, just had my phone a day, when i notice a blue spot against black or dark backgrounds. its very distracting as you can imagine. Has anyone else had this issue. I have tried the few pixel fixer apps with no luck, is it worth trying them again for longer?
Should i get the phone exchanged? what are the chances of getting another fault? Is it common?
Thanks if anyone can advise.
yeah go ahead and exchange it ASAP after all you spent lots of $ for it and it should be perfect specially the touted SAMOLED+ screen
I don't think anyone here has reported a burnt pixel yet so likelihood of getting another is slim, get her swapped.
Mine has one partially dead pixel. when viewing a completely white background, if you look really carefully you can see a tiny little red dot. It's so minor and unnoticeable I didn't bother changing it.
