Currently stuck in the middle of the rooting process with nowhere to turn.
I have followed The Unlockr instructions as recommended by B2L and it has proved very good.
However, I have got to the point where I download the superuser.zip and place it inside the phone's USB storage.
The instructions say to put in the root part but all I have is one screen for the phone...so I cut and pasted the superuser.zip file into there.
However, when I came to the next option of "flash zip to sdcard" I had no option for this. All I have is:
reboot system now
apply sdcard:update.zip
wipe data/factory reset
wipe cache partition
install zip from sdcard
backup and restore
mounts and storage
advanced
go back
So I have stuck. Will it have anything to do with the file being a Win RAR zip file? (I dont know but just curious).
Should I have been able to see a root file when connecting my phone as mount and storage?
I hope someone can help me asap.
Thanks
reboot system now
backup and restore
mounts and storage
advanced
go back
Thanks
