Root Stuck In A Bootloop
1saint10
I finally got s-off on my htc evo v then folowed the"Fix everything by turning your phone into an Evo 3d" thread tand updated my hboot but now im stuck in a bootloop.
The problem is likely that you are using a rom that doesn't play well with your hboot. If you haven't made a backup or need back into your current rom for something, I would suggest changing your hboot back. Then you should be able to boot up.
Otherwise, leave as is, boot into recovery and flash a different rom, one that works on your hboot!
What rom are you using?
I was on Harmonia
I haven't studied the guide thoroughly but can you try midnight rom since it suggests either midnight or harmonia?
Well that's good! Hmm do you have your usb debugging enabled in settings? Possibly it has turned itself off after flashing a new rom?
