Root Stuck in clockwork mod
gorritzg
Well, I had my LG Esteem rooted a long time ago, and everything was going perfectly fine.
About a month ago, I got a new phone. I kind of just disregarded my Esteem, until currently, a friend of mine asked to buy it. So, I did a factory reset, without thinking, clearing my SD card, internal memory, etc.
Now I'm stuck in ClockworkMod and I can't restore a backup, because as I said, I cleared everything.
I remember I did the same thing a while back. The only problem that I'm facing is that my computer doesn't recognize the LG Esteem whenever i plug it up via USB.
The last time, I had to switch out the SD card in the phone, to a camera, hook up the camera to the computer, and download something onto that (I think at least).
So, if anyone could help me with this problem, I'd be extremely thankful!
I guess, all I really need is the download link to whatever I have to restore onto my phone, and the instructions on what to do once in ClockworkMod.
Thanks in advance.[:
This thread here has a fix for your issue....
http://androidforums.com/esteem-all...eset-read-first-exit-recovery-d-l-inside.html
Good Luck ;)
Well, I'm not at my computer at the moment. I'm on my iPhone. But I'm assuming that the link was the same as the "bootloop recovery fix" or whatever. Anyways. Yesterday I downloaded that, and started up the phone. I went to the "meta-inf" and the "tmp" files. (The ones I downloaded) and it proceeded to tell me that there were no files within those folders. I checked the computer. And they were there. I'm not sure what happened?
