Beel
Im attempting to flash Bonsai4.
I get into CWM and i load update.zip text goes orange and i do what i was taught which is to 1st wipe data/factory reset (this is after a backup initially), then i wipe cashe partition, (it gives 4 messages saying E:Can't open /cache/recovery/log [twice] then E:Cant open /cache/recovery/last_log [twice]) then when i go to "install zip from sdcard" -> "chose zip from sdcard" -> Bonsai4All_Leafless_v4.0.1.zip it begins and it looks like this :
-- Installing: /sdcard/Bonsai4All_Leafless_v4.0.1.zip
Finding update package...
Opening update package...
Installing update...
assert failed: getprop("ro.product.device") == "SPH-D700" || getprop(ro.build.product") == "SPH-D700"
E:Error in /sdcard/Bonsai4All_Leafless_v4.0.1.zip
(Status 7)
Installation aborted.
then it brings me to the 4 options of "apply /sdcard/update.zip" , "chose zip from sdcard" .... and at the top it says to "apply update from .zip file on SD card" so when i attempt to do so and select yes it loads some lines i cant read fast enough then it brings me back to "reboot system now" ... and at the bottom it still says
ClockworkMod Recovery v3.0.2.4
E:Cant open /cache/recovery/log
getting anoyed with this...
and im somewhat new to rooting, ive done a lot of research but not too much into the actual doing
thanks guys n' gals!
(Status 7)
