Root Stuck in cwm after master reset
Hi everyone I had gingersteem extreme ii installed then i did a master reset this morning, to go back to stock, now I am stuck on the Clockworkmod Recovery v5.0.2.8. i cant reboot sytem or anything.. Ne help plz.
Just install your ROM again so you can boot up. Then follow my guide for going back to factory.
NEVER EVER do a reset through settings/privacy. ALWAYS do it in CWM!!!!!!!
Thanks.. Yess I did do a reset through settings.. Im back up now.. Now I got know wifi..:(
did you wipe data/factory reset, wipe cache, and wipe dalvik cache before installing a new rom? You might want to format data, system, cache under mounts and storage.
