Root Stuck in eHRPD..
I recently flashed bliss pop, didn't like it, and flashed back to stock rom. My data connection is now stuck in eHRPD and won't switch over to Lte. What is eHRPD and how can i get it to switch over to Lte. Thanks crew.
Side note. Tried dialer codes and prl update(s)
Which dialer codes did you try? Some work, others don't.
Those are the RTN dialer codes, huh. Dumb question, is it set to 3G only?
You can download shortcut master lite,
Search rat, open rat selection menu, choose automatic, reboot. Goto settings and choose lte/cdma. Reboot.
Another dumb question: did you do Profile update? You also need to run that one.
Yes, i did do an profile update. I was literally within 1000 yards of a sprint/vm tower as well. Got nottin. I'll try the shortcut master lite deal. Standbye.
