Help Stuck in Recovery mode! HELP!
appleboy2
I recently bought a password-locked LG Venice that I needed to factory reset. After coming to the recovery menu by pressing Power and volume -, I couldn't select anything. I can move up and down but the power button doesn't do anything. The home button just gets rid of the menu and shows the background android logo with an exclamation point triangle. Restarting brings me right back to the recovery menu. How do I get out?!
If your phone is in recovery mode you have no choice but to restore it.
How to Fix iPhone Stuck in Recovery Mode
All the data on it is already lost if it is in recovery mode, you will have to restore it and when setting it up again at the end of the restore process your phone will restart and you will have to set it up again as you did when it was new. In the process you will be given the option to restore it from and iTunes or iCloud backup. If you have been backing up to iCloud choose that (be sure to plug your phone in to a wall charger as this will take hours to complete).
More: Recover Data from iPhone Stuck in Recovery Mode
