Stuck in recovery mode
  • Start date Start date
D
Deleted User
Guest
My Samsung Tab A is stuck in recovery mode. Selecting the reboot system now option just gets it stuck in a boot loop and i can't get past the logos so I have to go back to recovery mode. I tried wiping the cache, doing a factory reset, and mounting the system and those did nothing. I haven't tired applying update from adb, and applying update from SD card as I'm not sure how to do it. I tried connecting my tablet to my windows 7 laptop but it won't connect unless I select the "apply update from adb" option. I'm not sure what to do.
Get the firmware for your device and Odin, boot into download mode and reflash the device firmware.
I'm not sure what caused your issue.
Further details will offer insight
Yes but my laptop won't recognize my tablet unless I select the "apply update from adb" option.
The issue was probably caused by me wiping the cache too many ties because my tablet kept randomly getting suck at the battery with a lighting bolt icon thing.
yeah you will need to be in download mode and not recovery mode. vol down+home+power....just to be sure as the recovery mode is vol UP+home+power.
and like @James L mentioned, it would help to know what exactly happened?
Oh, I didn't know download mode was a thing. Thanks
go to sammobile and locate your firmware and download it. get odin setup, hook your phone and have odin update your device. you should be good to go after that.
How do I know what firmware to download?
It seems there are multiple versions for the firmware. Does it matter which version I download?
