mandy052879
I am stuck in recovery and can't get out. I rooted and was going to install harmonia and got a little ahead of myself and forgot to install the recovery. Is there any way to fix this? Thanks for any help!!
How do I do this? Thanks!Refresh with jcase method in lgnpst
sounds like you are stuck in stock recovery. there is a way to recover from this (assuming your computer will still recognize the phone so the original setup can be reflashed using jcase root method) but will require some work on your end. http://androidforums.com/elite-all-things-root/564734-lg-optimus-elite-root-vm696-virgin-mobile.html
it sounds like you flashed harmonia via stock recovery vs cwm recovery..unclear, but if that's the case this may be your only option if the flash didn't wipe out the phones ability to be recognized via USB.
not saying you can't pull this off,but it is an involved process. you'll also need msl code...seeing as you didn't actually flash anything and the phone went into loop on its own,I'd suggest calling VM and tell them your phone started looping in recovery mode and won't exit it. depending on how long you've owned the phone,they'll send you a replacement.
I bought it at Best Buy in May. Would Virgin Mobile still send me a new phone?
