Root Stuck on android screen
nervjiggy
I try to start my optimus t and it wont get past the android logo. I rooted, installed titanium backup and deleted some of the stock apps. Now it wont get past the android logo. I've tried the hard reset. What do I do?
Hello nervjiggy. Prior to the factory data reset, did you go into the recovery menu and wipe everything?
My husband has he same issue, he attempted to root his Optimums T last night, it seemed a success and then pop ups with force close kept popping up so he turned it off. When he powers it back on it doesn't load past "Android" screen. Any suggestions on how I can get his phone back to working properly? Even if it isn't rooted is fine, just working properly period. Thanks in advance for your help.
SOLVED
Please see my thread and how I fixed it if you are having the same issue
Good luck & Happy Hacking (;
When you try to boot up the next time use the vol. down+home+power key and then if you get a factory reset (box w/ android) you should be good, I did this to my husbands phone and it got me past the "Android" screen but when I got to the home screen it was all still the same, rooted and all. . . Hopefully it works for you also :)
I haven't rooted my optimus t.. yet its stuck on the LG logo screen and then it will only allow me to enter emergency mode ... nothing else,,
so when i try anythinq else the keys flash...
just wanted to say this was absolutely a solution that worked. i did nothing but install a app and my phone did the same thing stuck on android. i called tech support..nothing,took it to metropcs corporate store...nothing!!! But i come here and instant help thanks a ton!!
I was able to fix this on the same phone just by opening the back, taking out the battery, putting it back in, then restarting my phone.
I would suggest people try this before doing a factory reset.
I also have the same problem with my galaxy ace S5830. what happened was, i tried updating to ICS 4.0.3 without rooting the phone first. please help me. cant afford to pay a professional fee so i wanted to o fix it on my own.
i have the optimus ls 670 and it wont load past the android screen so i hold down vol+home+power and it takes me to the reboot screen but when i reboot it dosent do anything the options ihaveare
reeboot now
apply sdcard;update.zip
wipe data/factoryreset
wipe cache partition
