Help stuck on boot animation
wapile
I was attempting to flash a ROM for the first time. my droid is rooted, I thought I was doing everything right, obviously not. I was using clockwork to flash it. I have titanium backup, and I had it clockwork backed up. It said the flash worked, I tried booting, and got stuck on the "droid" animation, it loops over and over. I booted into recovery mode, cleared data and cache. Now I can occasionally get it through the normal boot animation, all the way past the droid eye, but then it goes back to the "droid animation", only its very glitchy, and loops erratically. What should I attempt to do?
my suggestion is to go to the all things root section, read the guides on the sticky, and make sure you did everything correctly...
mine looped after flashing my first theme and i thought i bricked but after a couple battery pulls and reboots i left it alone for like 5 minutes and it booted up fine...
good luck!
