Root Stuck on Bootloader after GB data/cache wipe..
Bert336
Member
Hey guys i am stuck as the OP, i dont know if i should start a new thread or not but my problem is this.. i went ahead and applied the GB rooted .zip and then while i was at that same screen i wiped cache and data....booted up into bootloader screen. I did an SBF "SHADO_X6_2.3.34_SYSTEM-ONLY" and it goes through the whole SW update in progress but once it gets done i get back into the Loader screen. Any help will be appreciated. thank you
Bootloader 30.04
Err:A5,69,35,00,3D
ok so i ran into the same issue again, im trting to install rooted GB... i renamed the rootedGB to unpdate.zip... installed it, when and loaded zip from sdcard.... looked for the CRT effect add-on...rebooted the phone...back to bootloader...am i doing something wrong? should i boot the phone before installing the CRT addon?
It may need a full boot cycle before applying the TV zip. But it looks like p3droid has a deodexed zip with the TV animation on now.
Screwed here too. I've definitely moved to the .340, and managed to get Bootstrap Recovery to work after regaining root via Z4. However, after choosing the deodexed GB zip I am stuck on the dreaded M logo. I'm about to give up for the evening.
