Root Stuck on bootloader....
chaos3232
Hey how's it going? I'm stuck in the boot loader. I had CM7 installed before and it got stuck in a loop. So, tried wiping cache/data and dalvik. Dalvik couldn't be wiped. Tried installing another rom and that didn't work at all. I'm able to get into recovery mode without a problem, but now I'm getting stuck on the HTC screen.
Error wise, I'm getting the following:
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
I've looked around for some help and couldn't find much help, but it was a recovery issue/ Don't have a backup or anything, and don't mind wiping everything and starting from scratch anyways. When I try to connect the phone to the computer, it says device not recognized.
Try to manually install the drivers. Or check the drivers on the computer uninstall/reinstall them
Tried already and nothing. I tried HBOOT usb and that will oly say there is a problem with the device and cannot connect. I tried mounting the sd card and that worked fine.
Still havn't ben able to fix anything yet.
Fixed! Reflashed and added a different bootloader on it instead. It worked and I was allowed to boot from the .zip
i'm having the same problem. and getting the same errors that you reported. I'm able to connect it to my pc fine though.
what exactly did you "reflash" to get it working? right now i'm trying to just reflash an RUU but it's not looking good.
