Could be a problem with the battery. If it's plugged into the USB, does the light go solid?It also seems like I cant get the phone to charge.If I try to power down plug in usb charger I get a red light that intermittently cuts on and off every 30 seconds or so?I even have a wired one same thing?Should I get a wall charger and charge the battery then see if I can get it to boot?I have been putting the battery in the freezer for a bit, then taking it out.t seems to have enough charge to get into fastboot and run and load the ruu.
fastboot flash recovery recovery.img
. Before running any more RUUs I would try the factory reset and clear storage options in hboot. It could something lurking somewhere the ruu doesn't update,but the stock recovery can clear.
i have an unlock code.I tried in fastboot to flash recovery it says remote signature verify failed
could you tell me the proper commands to clear storage and factory reset?Can I do that in fastboot?When I factory reset just goes in bootloop?
I just checked and there is no clear storage option in the Evo 3D hboot and you have to press the power button once to select the bootloader (hboot) functions that include factory reset.Just select those options in hboot. You may not have the clear storage option until ics,or the 3d may just not have it.
So you have tried the factory reset option in hboot?
