I need assistance! When I startup my phone, it'll go into landscape mode without me even turning the phone. I have it set to auto-rotate normally, but I've since turned that off. Any clue why this would happen? I'd prefer to have auto-rotate turned back on.
rooted? yes. i thought i had made a backup but i didn't see it when i went thru recovery and checked. well, there was one but it's from last week. does it override the last saved file or would both be listed? idk. i think i screwed up.
No big deal Just put a ROM and the Gapps on your uSD card. Go back to your recovery and wipe cache partition, dalvik cache (in the advanced section). Go to the "mounts and storage" section and select format boot, data, cache, and system. Do not format the SD card as this will wipe all your data on the SD card.
Then install zip from sd card, select zip from sd card, select the ROM.zip first then the Gapps.
but now everything is gone. i have link2sd & had a titanium backup done. tried doing the tb thing first but ran out of space quick. should i have installed link2sd prior to trying to run tb? what's protocol here, sir?
