Help Stuck on Red Verizon Screen
rozwud
I installed an update, and it ended up getting stuck on this screen. I've tried factory reset multiple times, and every time it still stalls on the Verizon screen. Is there anything else I can do before I try to get a replacement?
PS - plus, if it was just a bad download on the update, if your local store has a service center they can re-install it and save you a replacement hassle.
