I have an test lg ally and im trying to play around with it and since it isnt on any contract i cant activate it, so i was wondering is there a way to get around that?
If it the screen where you touch the Android in the center your talking about do this: start with the top left corner of the screen. Tap that corner first and tap the other three going in a clockwise direction ending with the bottom left corner. This should bypass the setup for you.
i found an ally at work tossed away
so my first hacking attempts to clear sys apps i removed setup wizard and phone dial apps
your trick here helped ALOT thank you it got past the dam android touch me to continue that i couldnt get past lol back to learning on this phone before i do any others
