IM on . bell/virgin 2.3.4 is the normal android version.
I decided to to update to 2.3.6 using odin and xdadevelopers and it worked great. then just a few days later i heard about the update to ICS comming to bell/virgin in april. so i decided to flash back to 2.3.4 using the offical rom on xda. but ended up stuck on the start-up. only battery removal and setting to download mode to re-flash 2.3.6 removed the problem.
the thing is now im stuck on a non original rom and unable to use kies to update when ICS shows up. do i need to flash the stock kernel and the formware? anyone know what i am missing?
thanks in advance.
brian
thanks in advance.
brian
