Help Stuck on "starting download" bug
forza2020
Member
Sort out the frozen on "downloading" bug NOW.
Respond to complaints!
I have an Android phone, I should be able to download from the Market!!!!!!!!!
SORT IT NOW.
I'm going to email every Tech journalist I can tomorrow with the endless list of complaints about this bug on the Google forums.
A week now, and I can't download any apps.
Google are shit.
Wrong forum and calm down, it's a known problem and they'll fix it.
It's been going on for nearly two years!
I want it fixed now!
Calm down??? Would you like it if you couldn't download any apps?
And... How the hell do you contact Google to talk it through?
You just can't.
Appalling.
Its called turn off your wifi, and download it over your mobile connection. If you can't do that, well, I suppose your out of luck. :(
Although, downloading over wifi has been working perfectly for me the past few weeks.
Merging threads. Please do not make 2 duplicate threads as it is completely unnecessary.
Perhaps if you take your phone to your carrier they can help you sort this bug out. I only have a problem every now and then, and its usually because my internet is down or something, or my wifi connection isnt so good.
SORT IT NOW.
Why don't you clear your data in market, in manage applications and reboot the phone
