Hey guys, I'm sure this has been covered, but I haven't found a good solution. I have a coworkers nexus 7. She was going to throw it away because it will not boot up, its just stuck on the x animation. I told her that its impossible to 'brick' modern smart phones/tablets due to software, and that I'd take a crack at it. Within the first ten minutes I had it in the boot loader menu, got into the recovery menu, wiped everything, did a factory reset and.... Still no dice. It just sits at the x. There are various toolkits one can use from PC which sound awesome, however step one is always to enable USB debugging on the device. Seeings how I can't turn the device on, I can't enable USB debugging... I've tried and failed to install ota updated via sideload, and suspect the reason I can't get that to work is again because I am unable to enable USB debugging mode. If anyone has any suggestions that would be awesome, I hate to return this in an unworking condition, because I'm sure she is just going to pitch it!
