Root Stuck
Hardstyle
So i went to update to the new 2.3.340 downloaded fine and then asked to to install so i hit install now and 30 minutes later its still at the screen when you power it on and it shows the Motorola symbol. Before i updated my phone i was rooted and had the black glass theme. So is my phone bricked? and i have to unroot it? :confused:
Also right after i posted this my phone said droid and vibrated like when i get a text message and the notification green light is blinking so i was hoping it was turning back on but nope :( its still at the motorola symbol
Hit the power button like your going to turn it off(have to hold it a couple seconds) then "click" the screen right below the symbol. It will turn it off.
It's a video driver issue that sounds like its still there from the last update. Sometimes the video doesn't initialize correctly and it gets stuck on the motorola symbol.
i pulled the battery out
but then i went to go check if i was updated or not... and im not updated so im trying again
