Root Stuck
MrMondayNight
I'm stuck in a constant loop of the stock recovery the volume buttons work as does the power button but the buttons don't respond to my touch....
Do a battery pull. Let the phone sit for a minute or so then put it back in and boot the phone in to CWM (volume-down/power). If you still can't use your touch buttons, use the volume button to scroll down to the factory reset option and and use you POWER BUTTON to select. That should get-r-done.
I just tried it and the power button can be used to select.
