ousuxndallas
Member
I can confirm that if you mute your VZW phone, the shutter sound goes away.
I've tried it multiple times, and mute works 100%.
Where is the option to mute the phone?
Notification bar. Called "Sound". Click to mute, vibrate, or sound.
Tasker from the play store. Pure genius!
this is incredibly frustrating!! it seems that the option to disable shutter sound is only missing with Sprint phones!!!
In Tasker, press + to create a new profile. Name it (shuttersound or something).
When prompted, choose the context Application > camera.
Now choose the new task (name it if you want) audio > silent mode > on.
Add exit task > audio > silent mode > off.
Done!
This does it for me...
Thank you for the quick reply......gonna try it out!!!!!!
Edit: I tried it out..but no luck....is there anything im missing out..![]()
Does Tasker require root?
