Help stupid question but...
No such thing as a stupid question :-)
1. Plug the USB cable into your Wildfire and PC.
2. On the Wildfire, it should come up with a notification that you've plugged it in, you can choose Charge Only, HTC Sync or Disk Drive. Choose Disk Drive.
3. The drive will be mounted on the PC as a USB mass storage device.
4. Be sure to "eject" from the computer before disconnecting the cable.
Hope that helps.
