it may be the new version of swype that comes preinstalled with ICS as the main OS
i am in the process of installing CM10 on my nexus now so i wont be able to tell you anything until that is done![]()
I ve a smiley button on the swype keyboard. I have to hit "menu" then insert smiley. Thenings them up.
I don't have that option, there is a smile on the bottom right to long press, no option to insert under menu.....that's exactly how it was on the bionic though
Is that stable finally? ive been using aokp
