Root stupid thing thats bothering me
mikeydooodie
my phone app is still skinned with black glass since i used that to deodex. im running fabs revo apex and while it matches in color i just dont like the look. my question is how can i get this skinned to match my theme(if fab skinned the phone app which im guessing he did)
You could get the phone apk file from a different rom then just install it in the system/app folder and change the permissions..
can i get some directions on how to do that?
Apex uses the blurphone.apk so would need a themed version of that to replace it with. You can just download the ROM or theme, unzip the file then go into the system/app folder, pull out the blurphone.apk file and place the file on your sdcard Now go into the system/app folder on your phone and delete or rename your current blurphone.apk file. Then move the new apk file to the system/app folder on your phone, do not try to install it. Once you've moved it change the permission (by long pressing on the apk file using root explorer) to User: read, write; Group: read and Others: read, then just restart your phone. Just be sure to make a backup prior to doing this just to be safe.
ahhhhhhhhhh ok i gotcha i just need to find one that matches my theme
