Root suggestion to flash
chughgopal
Guys as we all know u Micromax has CPU of media tek.
So someone try sp flash tool
Its a special tool to flash mediatek phones.
Please someone give a try.
How to flash? :confused:
Now, open SP Flash Tool and make sure you mark USB Mode under Options tab.
Load the scatter file (MT6573_Android_scatter.txt) and ignore any message that may appear. After that, select the part you wish to flash into your MT65x3 based phone and make sure you select the right file location. In this example, it's shown the recovery partition.
With phone completely switched off, press F9 (or hit Download button - the third one with an arrow) to start download and when the countdown starts connect the USB data cable into your phone. To make sure your phone is completely turned off, remove the battery and replace it after a few seconds.
or check here
bm-smartphone-reviews.blogspot.com/2011/10/mt65x3-flashing-tutorial.html?m=1
mtk2000.ucoz.ru/down/down1/down3/ROOT_1.1.rar
try this tool to root the mobile can i confirm that it runs on mediatek
try this site mtk2000.ucoz.ru
it has lot of stuffs for mtk chipset ranging from drivers to phone suite
here is a phone suite
mtk2000.ucoz.ru/down/down1/down3/PhoneSuite_7.0.9.1.rar
imei tool
mtk2000.ucoz.ru/load/0-0-0-4-20 etc
Their is no response from the phone. Sp flash tool is showing as searching for long time.
I installed MT65*3 usb vcom drivers
ROOT_1.1.rar and PHonesuite are in china language
Flash tool v5 is not working.
@rudra can confirm that this phone runs on mtk 6573
Yes this phone runs on MT6573
Phone suite is in chinese. I am not able to understand how to connect
I think we have to enter the download mode. I don't know how to enter download mode in Micromax A75
thats now very easy
mtk2000.ucoz.ru/down/down1/down3/FlashTool_v5.1140.00.rar
and follow
m.youtube.com/watch?gl=IN&hl=en-GB&client=mv-opera-mini&v=097GkEDh-dA
mate you dont need to enter download mode your mobile is going to be switched off
and one more thing in this video he describes for lower end mt chipset which need some additiona wirecase but mt6573 dont need that
but the procedure is same
sp flash tool is able to read from MT6573_Android_scatter.txt
But Flash tool is showing as item failed
if scatter files work then try to follow rules at
bm-smartphone-reviews.blogspot.com/2011/02/mtk-hd2-hd9-flashing-tutorial.html?m=1
since it is for mtk 6516 procedure is same
@ Rudra. I used PC to update it. The files are the same as on given here.
The steps are as follows:
1) Choose download agent
2) Choose scatter loading file
3) Untick PRELOADER
4) Switch off phone, Install provided drivers (given in this forum)
5) click Download. The s/w will ask you to connect the phone(switched off)
Done.
@chughgopal, The phone seems a bit faster. ( requires more usage to confirm) but internal free space is now 135mb.
Will keep you guys posted. Tried with Gowthams files also, but it requires system.img file (a 200mb + file) which is not there. Should it be created with Gowthams files?
Any updates on rooting?
@rahulhnair did you tried system.img provided by micromax with gautams rom if you flashes with gautams rom it will get rooted
you used sp flash tools isnt?
I knew that file would help.
M searching more in this mediatek stiff now.
@Rahul Nair
Can u give the details from your about phone screen.
Kernel, baseband, etc
