rudrateja
I am also getting the problem with vcom drivers as device Unplugged. At once drivers are installed and disconnected.
I think rahulhnair is using different data cable to flash. Tommorow I will try to flash using nokia data cable.
Once I unfortunately pressed volume up+volume down+power and I got Factory mode which have the following options
full test
item test
test report
clear flash
version
reboot
In this menu what is clear flash. If it really formats the flash (so we will not get the battery animation) I think we can install the update. But I am afraid it will brick the phone!
@rahulhnair please use mediafire or sendspace to upload the files.
full test
item test
test report
clear flash
version
reboot
