Root Supah Clean DL09... problems with sync
gaw316
Member
So I installed Super Clean, stupid fast 1.54 kernel, and got a nice theme to go with it... (i believe it's called blackcombo? or something) anyway I love the way the phone looks and feels now... I just have one problem...
My facebook contacts, for whatever reason, won't sync to the phone (there images mostly). Sometimes it'll work.. but it won't sync all of them.
Are there any proposed solutions? Reflashing the rom? kernel? etc?
I have not experienced any issues on DL09, I am running adrynalyne's latest kernel.
Test Kernels From Adrynalyne (updated 1/18 w/ cd rom bug fixes) - xda-developers
would you say that his kernels are better than stupidfast 1.54? ... or just as good... i've been running that and I've liked it so much so far...
Adryns kernels.are jt1134 based with voltage tweaks (and now the phone as cdrom big squashed) so if you like jts but are looking for better batt life adryns are good
Thanks man.. what's the dif between standard voltage and low voltage and the implications I would notice if you don't mind me asking
generally the lower the voltage, the better the battery life you will get...to a point...i think either -100 or -125 is the ceiling and after that its counterproductive
however, not everyone can run anything but the smallest of undervolt (-25) without lockup or the phone not waking up...its really a personal experimentation to see what works on your phone
Agreed. I tried the -150 and it was way worse than -100, never tried the -125 just figured -100 was good enough. Honestly outside of david Im not aware of anyone who cant take -25mv at 1Ghz:p;).
But as you said the absolute truth is you dont know what your SF can do till you find out yourself thru testing it
for me -100 is it...-125 was noticably worse battery life over the course of a day or two...but it might be different for others i suppose
yeah I think back in december adryn pretty much said the bottom end was -100mv, Some like the -125 but I think its like any uv ymmv. No one seems good on the -150 so imnuts does even make it either.
Im currently on imnuts -75 for aosp because thats the one he dropped last night and its much better although now I see the -100 is up so away I go ;)
I usually like being singled out and seeing my name but not for that;)
And for everyone that said good luck this morning good news.. Got the job :D I start monday.
Thanks you guys its a BIG relief
Congrats Amigo :D:)
